TK380 scan list help
K2NEC
NA
I'm trying to program a TK380 to scan the channels in the system. I have the scan button programmed, in scan info I have "Fix System Scan" selected, but it still doesn't seem to be scanning the whole system. When I select "List Type System Scan" I am able to check the boxes in the system data labeled "Scan List" but same results.
The channels work I just can't figure out why it's not scanning them. Is there some trick I am missing?
I'm also trying to figure out how the scan add/delete button works, but one step at a time.
hill
Middle River, MD
You need to have the channels you wish to scan enabled for scanning. The TK380 should show a triangle on each channel that is enabled.
I don't use a scan list, but just add and delete channels want to scan at the time.
Also you need to have a button assigned to scan and another for add/delete.
K2NEC
NA
Is there a way to enable the channels in the software? Or is that done via front button?
I have it pretty much figured out now. My problem was that I had "Group lock out" enabled which should be disabled. Seems like it's scanning fine now.
When I press the A/D button it shows a triangle by every channel, which is what I want, but what if I want to disable a specific channel? When I press the A/D button it seems like it just shows me which ones are in the scan list.
Edit:
It also seems like it's scanning both zones. I want it to scan them separately. How do I go about that?
hill
Middle River, MD
I think you can check one zone or muti zones to scan in the scan menu.
I never used a scan list. Just pick a few channels that wish to scan.
Each channel in the software has a field to add each channel to scan.
hill
Middle River, MD
Since it says group rather than channel you must be in the LTR Trunking System, rather than conventional channels.
K2NEC
NA
Ohhhh I see. I had no idea I had to change it in model information. Sure enough it was set to trunking. Will update when I play around some more and reprogram my radio
K2NEC
NA
Yea that seems like that solved my problems. I had no idea there was a trunking and conventional setting. Thanks for that
