TK790H - Dual remote heads....do both heads need to be the same?
johndjmix
Hey guys, setting up one of my race rigs with a Head inside and one outside. For the outside one the head with the built in speaker would work better, where as up front in the cockpit the advanced head with an external speaker is installed.
Wondering if i can mix heads on a dual head setup? If so, how will the button programing work?
Thanks.
--John
N5XPM
Texas
Thanks.
--John
The remote heads can be different. Programmable buttons on each Control head are programmed separately in the software.
Reelfishguy
I THINK that some of the actual frequency information is stored in the control head. So if you swap a Basic Head with a Full Feature Head some of the frequencies will not be correct. Like channels 1-8 may be correct, but 9-32 may be wrong. That would apply to a single head radio.
LATA 722
No, it's stored in the radio, not the control head.
KK6ZTE
California
I've had some wierdness swapping heads around when I had a bunch of 790s and 890s. There may be alpha-tags stored in the control head.
On newer (5x10+) it's all in the body. But the 790 does have some info in the heads, you'll just need to push a new file to it.
LATA 722
It's all in IC519 on the control board in the RF deck.
There is some processing done in the control head, but it doesn't store memory. It's control signals from the control head to the control board.
