TK8180 Programing with PRYME Blue Tooth adapter
deleontow
Need a little help to program the function of the PRYME Bluetooth adapter on the D-sub 25-pin connector. I have the KPG-89D program and the correct KPG-46 Cable to program.
a417
Wha?
The 8180 doesn't have integrated bluetooth support, or the ports required to support the PRYME bluetooth models that plug into portables, as the 8180 is a mobile.
What unit do you have?
deleontow
TK 8180, has a serial port on the back. Radio settings have to be changed to utilize the blue tooth which plugs into the 25 pin serial on the back of the radio,
a417
Ah, I stand corrected. I was unaware that iteration of the product existed. live and learn!
Did any documentation come with the device that delineates what I/O it's looking for on what pins? You will find what you are looking for under "EDIT" --> "EXTENDED FUNCTION" tab in the -89D software. Without knowing what it needs, can't tell you what to put where.
Most of the pins on the DB-25 are already assigned for audio out, mic in, and power. You'll need to assign one of the IO ports for PTT. You will need to know which pin on the DB25 the bluetooth adapter is looking for it.
MI2 = Pin 6 (this is the Microphone level input TO the radio FROM the bluetooth connector
ME = Pin 25 (Microphone Ground)
AFO = Pin 17 (Filtered Audio Output FROM the radio TO the bluetooth device)
Ground = Pin 7
The PTT needs to be assigned to the correct pin to match the bluetooth adapter. That'll depend on how its wired and the manufacturer should tell you this. You'll set this under the "Extended Function" tab, specifically under "AUX".
You will then need to go into the "Modulation Line" tab and set up the MI2 (rear mic) setup.
Sent MI2 line to "Connect"
That should get you started. There may be some other settings to adjust, like the external mic gain, but get it all functioning first before adjusting that.
