TKR-750 Battery
powerlineman
Any suggestions on buying a backup battery for a TKR-750? Should I just run to the local auto parts store and buy a marine type battery or look for something else? I know they make "ups" batteries but are they really any different than a deep cycle marine battery?
vzfarms
ohio
Any batter would work, depending on the application. A UPS battery is just a sealed lead acid deep cycle battery and any battery of that type would work. If your repeater is in a building you should use a sealed battery.
ramal121
Lots and lots of watts
Calif Whine Country
You get what you pay for. Just don.t use an automotive "starting" battery. Plates are thin and will fail
when least expect them to.
BTW. Setting a jumper in the TKR will provide a trickle charge to keep a battery topped off. It's not enough, though, to charge a battery that is well discharged.
OC05450R
Orange County,NY
you can find ups on sale for pretty cheap sometimes at Best Buy or online....sometimes less than an automotive type batter and definatly cheaper than a marine-JOEYD
