TKR-820 Keeps repeating after I leg go of my handheld PTT
cdesigns
Clermont, FL
Guys I bought a TKr-820 repeater on ebay and I have been trying to program it and test it. I know the frequency of the repeater but I dont know if it has a PL code or not. I tested ALL the pl codes even the digital ones and none activates the repeater. No matter what PL code I use, I can hear my voice on the repeater everytime I press the PTT on my handheld, but I cant get it to repeat...........The only way I can make the repeater "work" is if I remove the PL eeprom chip, but once it starts to repeat it keeps repeating until I turn off the unit.
The white plug jumper on the back is set enable the speaker, there is nothing disabling the internal controller. I have NO MIC connected to the repeater, do I need one to make the repeater work correctly?
tornado229
VA
Sounds like it needs a good alignment. Your receiver / squelch is too sensitive and when it opens it never closes.
Sent from my MB860 using Tapatalk 2
nwradiorick
Houston
What PL is Transmiting? If you plug a Kenwood mic and key it will transmit the first PL programed in the list. In most case the encode and decode are the same.
