TKR-851
bucknut937
Fostoria, ohio
I recently bought a TKR-851PSD from kenwood with a duplexer. Once it was all hooked up it worked fine. Now all of a sudden it just started to make all the transmissions grabbed and somewhat distorts the audio.
There is no power amp on this repeater and it putting out 21 watts, which is kenwoods specs for the radio. I will try to upload a sound clip to this forum later.
Thanks,
ZAC
T0mSmith
Are you sure that it is the repeater and not the transmitting radio that is causing the problem? Have you tested this problem with multiple transmit and receive radio combinations?
bucknut937
Fostoria, ohio
yes i have used 3 diffrent types of radios and it's appears to be the systems, I have multiple PL tones in the repeater some are PL and some are DCS. there is only one user on the system at this time due to this problem. Later on down the road they would like diffrent ch for diffrent areas of operation.
Thank,
ZAC
T0mSmith
I'd like to hear that clip. Are you using any type of scrambling or voice inversion?
