800 | 9632 | A | TLC | Taxi and Limousine Commission | Transportation | Taxi and Limousine Commission | |
800 | 9664 | A | TLC | Taxi and Limousine Commission | Transportation | Taxi and Limousine Commission | |
800 | 9696 | A | TLC | Taxi and Limousine Commission | Transportation | Taxi and Limousine Commission | |
800 | 9728 | A | TLC | Taxi and Limousine Commission | Transportation | Taxi and Limousine Commission | |
800 | 33168 | D | TLC Ch 4 | Channel 4 | Law Tac | Taxi and Limousine Commission | |
700 | 2063 | D | TLC Ch A | Channel A | Law Dispatch | Taxi and Limousine Commission | |
800 | 33008 | D | TLC Ch A | Channel A | Law Dispatch | Taxi and Limousine Commission | TG 2063 ON 700 |
700 | 2064 | D | TLC Ch B | Channel B | Law Dispatch | Taxi and Limousine Commission | |
800 | 33024 | D | TLC Ch B | Channel B | Law Dispatch | Taxi and Limousine Commission | TG 2064 ON 700 |
700 | 2065 | D | TLC Ch C | Channel C | Law Tac | Taxi and Limousine Commission | |
800 | 33040 | D | TLC Ch C | Channel C | Law Tac | Taxi and Limousine Commission | TG 2065 ON 700 |
700 | 2066 | D | TLC Ch D | Channel D | Law Tac | Taxi and Limousine Commission | |
800 | 33056 | D | TLC Ch D | Channel D | Law Tac | Taxi and Limousine Commission | TG 2066 ON 700 |
800 | 33152 | D | TLC Ch J | Channel J | Law Tac | Taxi and Limousine Commission | |
800 | 33200 | D | TLC Ch M | Channel M | Law Tac | Taxi and Limousine Commission | |
800 | 9680 | A | TLC Enforce | Enforcement Common | Law Dispatch | Taxi and Limousine Commission | |
800 | 9648 | A | TLC Enforce | For Hire Cars Enforcement | Law Dispatch | Taxi and Limousine Commission | |
700 | 2074 | D | TLC Fleet | Fleet Operations | Law Tac | Taxi and Limousine Commission | |
800 | 33184 | D | TLC Fleet | Fleet Operations | Law Tac | Taxi and Limousine Commission | TG 2074 ON 700 |
800 | 9744 | A | TLC Inspectr | Inspector General | Law Dispatch | Taxi and Limousine Commission | |
800 | 9616 | A | TLC Medlln | Medallion Cab Enforcement | Law Dispatch | Taxi and Limousine Commission | |
700 | 3051 | D | TLC Special OpsA | Special Ops A | Law Tac | Taxi and Limousine Commission | |
700 | 3052 | D | TLC Special OpsB | Special Ops B | Law Tac | Taxi and Limousine Commission | |
800 | 9712 | A | TLC Supervsr | Supervisors | Law Dispatch | Taxi and Limousine Commission | |
700 | 2073 | D | TLC Woodside | Woodside Inspection Facility | Law Tac | Taxi and Limousine Commission | |
What model radio are you guys using in sanitation?I've heard nothing either...
on a side note ... I work for Sanitation and they just moved us to the P25 on July 14th and the consensus is that it needs work. I have answered transmissions and my reply was not received on the other end - it's garbled and unreadable - whether in the car, on the street or in a building.
The UHF worked just fine.
They’ve got APX4500 mobiles for sure. Not sure about portablesWhat model radio are you guys using in sanitation?
You're still on UHF T-Band, just a different system. Same frequency range of 482-483; they took channels from the SmartZone system and moved them over to the ASTRO 25 system.The UHF worked just fine.
Your screenshot indicates that they are now operating in TDMA mode, so I wouldn't exactly call that "no change". I've updated the mode in the database.They are active currently on the 7/800 MHz side, no change.
i'm off this week but I'll check when I go back Monday. They gave us all new radios last year but APX4500 as mentioned by another poster sounds right. The base radios were never switched out.What model radio are you guys using in sanitation?
CQDX, could you do a Channel Activity screen grab for the UHF side of the P25 system? Thanks.
The UHF cell info is accurate and up to date, I checked it recently. What exactly are you looking for?CQDX, could you do a Channel Activity screen grab for the UHF side of the P25 system? Thanks.
Which channels are TDMA, like the two in the 700 group and the four in the 800 group.The UHF cell info is accurate and up to date, I checked it recently. What exactly are you looking for?
They are all TDMA capable. Don't be misled by what you see in the screenshot of the 700/800 cell. ASTRO 25 systems will not use the BSI or alternate control channels for traffic unless all other traffic channels are already in use.Which channels are TDMA, like the two in the 700 group and the four in the 800 group.
