Tn Homeland Security D7 NXDN
RJDII
Nashville Tn
Still not getting anything. I am using (INDOOR BASE OR MOBILE SCANNER ANTENNA, WITH BNC CONNECTOR, FOR HOME, APARTMENT, OR OFFICE - ALL BAND 25 TO 1300 MHz - USE WITH EITHER ANALOG OR DIGITAL SCANNERS - INCLUDES HEAVY DUTY 5" CHROME MAGNETIC
BASE). I am in Hendersonville on Sumner/Davidson line.
buddrousa
Back to the basics.
#1 Did you buy the NXDN and what scanner are you using?
#2 You are not going to hear 32 air miles away on an inside antenna.
#3 Did you drive up to springfield and test your programming?
#4 Are you using the latest data from the RR Database?
W5RGP
Charlotte Tn
In Hendersonville I don’t think you will even pick up the whitehouse site
I updated a lot of info on this site a couple weeks ago some control ch changes too if you don’t have the latest rr download in sentinel you may be off a bit too
But 32 air miles is a bit for this system with an inside antenna at that
I’ve got a discone 40’ in the air and can barely pickup the whithouse site and some of the waverly site
I’m near downtown Charlotte
RJDII
Nashville Tn
#1 Did you buy the NXDN and what scanner are you using? yes 436 and 536
#3 Did you drive up to springfield and test your programming? not yet will do
#4 Are you using the latest data from the RR Database? yes
W4EMS
NoVA
From west side of Murfreesboro with a Comet GP-9 at 35 ft fed with LMR-400 primary (2M/440 Ham) I get about 60% of White House and a bit more from Springfield. With regular scanner antenna about 10 feet below, nothing. They seem to be well adjusted on power to prevent interference to other systems outside of the jurisdiction.
INDY72
Indianapolis, IN
Due to those limitations, that is a main reason that White House Community VFD uses TACN for its tactical/fireground operations. Much better coverage in the areas they serve. Currently still dispatched on the D7,.. For now anyway. They get TACN deep up into Kentucky on mutual aid runs, and all throughout Sumner etc. Like other users of that D7 Greer run machine,.. I would be looking for big changes once contracts are up.
W5RGP
Charlotte Tn
Yep see my post above dickson will most likely be moving to the tacn around March when contract is up with Greer I believe early testing will begin before that
They are going to have to put up 2 towers they already know
KD4YGG
Looking for any additional submissions for this system.
Specifically, looking to close the following gaps.
Channel #’s from either DSD-plus or BCD436/SDS-100 LCN Finder output are acceptable
Cross Plains – Robertson County
Need Channel #’s for the following listed frequencies:
460.2625
460.3700
460.5875
Cedar Hill – Robertson County
454.6250
460.2500
460.6375
461.7375
Dover – Stewart County
453.721875
460.296875
460.300000
McKinnon – Stewart County
Need Channel #’s for the following listed frequency:
460.2875
New Johnsonville – Humphreys County
460.1125
Waverly – Humphreys County
460.6000
Stewart – Houston County
Need any and All Channel #’s and frequencies confirmed for site 10
460.36875 is the listed control channel
Other frequencies exist, need to search and discover which are being utilized.
Sage Hollow – Houston County
Any and All Channel #’s and frequencies confirmed for site 09
453.7875 is the listed control channel
Cunningham – Montgomery County
Which listed frequency is being utilized as Control Channel ?
Woodlawn – Montgomery County
Thanks in advance
W5RGP
Charlotte Tn
I’ll be home for about a week for Christmas will try to hammer some of this missing info out then
W5RGP
Charlotte Tn
Just checking to make sure my submissions I sent in last week did go through
Haven’t seen the updates posted yet but it has been a holiday week
