Toggle Alpha Tag vs TGID on BR330T?
bfeeny
Royal Palm Beach, Fl
Is it possible to toggle to view the actual TGID instead of the Alpha Tag when scanning on a BR330T? I want to look to see if the status bits change from time to time, and if I could see TGID I would see it jump, but I don't really see that with Alpha tagging, because I believe even if the Status Bits change the Alpha Tag is tied to the first 12 bits so it does not change.
Brian
Press the function key and #5 at the same time and this will remove all alpha tags, Do the same to restore alpha tags.
