Pro-95
So I went down and got some homebrewing antenna making supplies. Spent 14 bucks. Got a 4"x10' hunk of PVC for my "mold" or "tool" to spin the helical section. Bought another 25' of #4 solid copper.
The plan is to keep the helical section on the 4" tube for now while I play with the spacing and tuning. Once I find the "sweet" spot I'll pull the tube and place it over a smaller tube with spacing/centering pins. I'm undeceieded over the center tube material. Both PVC and wood dowel have their respective good and bad aspects. PVC is relativly light and is easily adaptable to drilling in studs for the centering of the heliax. A wood dowel is structually superior but adds complexity to the dowels. Both have a limited life span with PVC failing sooner due to elements and UV deteriotion. Wood will last longer but would tend to bend or bow in a long application with support only at one end. If I've missed an option please feel free to jump in.
On the reflector I'm considering spinning the #4 copper in a diminishing pattern and using soldered in place copper supports. Since I've seen most reflectors although starting as a solid plate ending up with several holes in them to reduce drag.
The overall length I'm shooting for is +8' but will do incremental spins to see if a happy medium can be acheived with a shorter lenght reducing the need for structual strenght and the weight associated with it.
I will conduct a small test spin on the remant sections of #4 I have to see how far I can go unsupported before the weight exceeds the integrity of the #4 alone.
Any thoughts on the materials is accepted.
