Toning under TDMA & FDMA P25 Network
Clearway2000
Looking for tones to use for alerting that will sound clear when played over a P25 network when TDMA & FDMA systems have been have been connected for out of area added coverage. No issue under TDMA, but when a user from a FDMA network bridges into the TDMA network the tones are garbled on that talk group.
Clearway2000
Through the DTC and DDM when one unit out of its primary network locks into the other network. When this happens they say the VOCODER does not play well pushing the tones over both system, thus its garbled. Looking to find any know tones that will work under both .
studgeman
The reason you are having this problem is tones are not encoded like voice, and when the are they sound like garbage. There was an extension a number of years ago where the tone is coded in the packet with specific byte code and then reproduced at the vocoder output. You have to transcode the packet inside the system. I cannot say that any one tone will work due to differences in radio manufacturers.
Clearway2000
Thanks for the reply... Currently tones are going over fine, but something triggers them to be garbled... Will work for months sometimes... All Motorola on the system
studgeman
You should open a support ticket with Motorola, as this is an intermittent issue and likely something at the system level. Might even be a software bug. This is a topic that is way down in the weeds.
