Topaz trs
FLANO
AZ DB Administrator
SE of Tucson, AZ
Hello All,
I've received private e-mails, postings in this forum, and submissions via the DB on this system. While I continue to work on the update, I thought I'd compile it together here for the moment.
System ID: 36B WACN BEE00
If a control channel was submitted, I added a "c" after the frequency. Can someone verify the control channels for me for each tower below please?
Also, please ID the tower number too.
WQJR970 – Thompson Peak
- 769.26875 769.51875 769.76875 770.01875 770.26875
WQKP625 – White Tank Mountains (Simulcast)
- 773.89375 774.14375 774.39375 774.64375 774.89375
WPNY928 – 8450 E Main St
- 867.100 867.125 867.250 867.300 867.425 867.600 867.675 867.750 867.825c 867.900 868.050 868.200 868.275 868.350 868.500 868.525
WPNY928 – 161 E 6th St
- 866.0125 866.0375 866.5125 867.0125 867.5125 868.0125
WPWD248 –
- 867.075 867.225 867.375 867.725 868.3625c
From input provided so far, it appears Mesa PD and FD continue to use the same TGID's.
Gilbert may be expanding to two dispatch and two info channels. So far, TGID 3050 is info and TGID 3049 is dispatch.
Thanks for everyone's assistance in cleaning this up.
Astrak
Mesa, AZ
Gilbert 3049 and 3050 are the current info and dispatch channels
Currenlty white tanks site with a control channel of 774.64375 and Thompson peak with a control channel of 867.725 are connected to TOPAZ. The only talkgroups I've seen coming off either Thompson peak or White tanks are encrypted talkgroups that are unidentified. Thompson Peak being site 302 and White tanks being site 303 and TOPAZ being site 301.
FLANO
AZ DB Administrator
SE of Tucson, AZ
Did anyone happen to bookmark the old TOPAZ system link?
Or do you happen to have the SID number ?
If I don't find it soon, then I'll have to create a new one from scratch :<
Thanks,
FLANO
AZ DB Administrator
SE of Tucson, AZ
Ok, thanks to the big help from MtnBiker on finding the old SID :)
I've modified the old entry with some of the updated information.
Need some help here in cleaning up the tech data. If you have the capability to determine site ID's, control channels, and/or neighbor site ID's, would you please submit an update to the database.
Also, based upon earlier reports, I only copied over the Mesa PD and FD Talkgroups from the RWC. I've added the Gilbert PD Talkgroups identified so far.
If you are able to confirm and/or ID some new Talkgroups, please be sure to submit those too.
Thanks for everyone's help, and don't feel bad about correcting the entry I have up on the TOPAZ system so far :)
http://www.radioreference.com/apps/dbadmin/?action=esys&sid=2082
Thanks,
FLANO
AZ DB Administrator
SE of Tucson, AZ
Hello All,
Ok, I've updated the TOPAZ system with input from several people. I've also inputted the Talk Groups active on TOPAZ, based on a several day observation of the TOPAZ system, with output from the program PRO96COM.
There are also some additional Unidentified Talk Groups active. Can you ID them?
311
403
3063
3095
3102
3103
3104 - Encryption Used, Very Active
3106
3112 - Encryption Used, Active
3113
3238
3254 - Encryption Used, light activity
3255
3261
3728
3740
3743
3745
3752
Thanks again for your assistance.
