Toronto Police and Fire Freqs.
Toronto, Ontario Canada
Thanks. I dont know if I will be able to listen to them or not.
The numbers there are listed in dec format and hex format (1072, 043).
I have a pro-43. Can I listen to these? and how would I enter these numbers into my scanner?
Thanks :D
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Thanks :D
That's a non-trunking scanner , so the talkgroup entering is out of the question. But, you may want to program 38 of the 42 frequencies listed.
Ignore the four primary control channels, your scanner will lock up on those frequencies.
By entering the freq's conventionally, you'll catch snippets of calls and have a vague idea of what is going on, which may suffice for the time being.
Have you considered buying a trunktracker ?
Thanks :D
Ignore the four primary control channels, your scanner will lock up on those frequencies. You'll catch snippets of calls and have a vague idea of
what is going on anyway. Have you considered buying a trunktracker ?
Which freqs. listed? The only freqs. that I see are EMS.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Not the talkgroup listings, rather this set of freq.'s :
  • (South) 857.1625 857.4125 860.9625 861.2125 861.4625 861.7125 861.9625 862.2125 862.4625 862.7125 862.9625* 863.2125* 863.4375 863.6875 866.3875 866.8875 867.3875 867.4625 867.7375 867.8875
  • (North) 859.5375 859.8875 861.9125 862.4125 862.6625 862.9125 863.1625 866.2375 866.7375* 867.2375*
  • (East) 860.2625 861.9875 862.4875 862.9875 863.2375 866.6125 867.1125 867.6125* 868.0875*
  • (West) 859.7125 862.1875 862.4375 863.1875 866.2625 866.7625 867.2625 867.7625* 867.9875*
IdleMonitor
The Ottawa Valley - Eastern Ontario
Just plug them in the radio and you'll hear everything you wanna hear. The system is a trunking system, meaning each conversation on each given talkgroup skips frequencies when looking for an open one to communicate on.
If you don't have a trunking scanner you won't be able to follow the conversations. Plain and simple.
Im using those freqs. and its working good enough for me. :D
So far, someone was about to jump off a bridge, death threat via cell phone, and someone was being beat by 10 people with baseball bats.
hmmm, what a wonderfull evening. :shock:
