Slight correction on the 102721, it's actually called "Events Ch3", and so far I've heard them use it only for shuttle bus operations.
The download link is at the bottom of every post the author has made on the topic thread.
Saw group 60002 used for an emergency transmission. Button pressed in error.
Same here 422.800 disappeared from the spectrum and the others look like they dropped 50% signal strength.Interesting... 422.800 died this morning... no signal at all. im barely picking up 422.6875
Hello,I've also discovered purely by accident, another frequency that appears to be TETRA, not sure if its TTC or someone else, 412.2375 with MCC 302 MNC 1563, LA 1, Color 1, which is different than the TTC. Currently no activity on it but I'll sit on for a bit.
I work downtown. 412.0625Mhz and I hear it here. its LA 31 and I live in Etobicoke so 412.9625Mhz LA:29 is extremely a strong signal. Also this morning before 6:15 Lots of activity on it there as well.Another talk group that's listed in the database 101013 - Surface Channel 3 does not exist on either 422.800 or 422.6875. I've heard it being called for units to switch to, to talk to the subway assistant (135A) and i hear nothing. For the past week I've also not heard it on 422.800, and I thought perhaps another frequency would have it, but no. I've also been watching the logs, in case this was marked as encrypted but it isnt. It just doesn't appear.
So this system is definitely not the same across the city when it comes to monitoring.
Just curious if anyone has heard this 101013 on a different frequency than those two.
