Toronto Transit Commission - PowerTrunk TETRA
HiVolt
Toronto, Canada
I have heard *some* calls that appeared to be to individual trains, but I have no idea if it was a line call or individual train.
On the old system all calls appeared the same on the scanner, whether they were an individual call, a line call, or even a "west" or "east" call.
Aurora
Just heard Wayside radio techs on 102701 doing upgrades to trains on YUS Line 1. They had them test a “PA” call to the train. Test came up on 100136.
They just did a ‘run’ call test to the ‘36’ run and it came up on 100136.
Also hearing traffic on 100002 that sounds like train yard type discussions.
They just did a Line PA announcement test for YUS run 36 and it came up on 100019. 100002 confirmed as Wilson Yard
So it’s looking like individual trains are being assigned a GSSI # based on their run number. Last two digits are the run number, third digit the line. YUS run 36 = 100136
Now confirming YUS Line 1 ‘Line Calls’ are on 100010.
Aurora
To recap, here’s what I have confirmed tonight.
100002 - Wilson Yard
100010 - Line 1 ‘Line Calls’
100019 - Line 1 ‘PA Calls’
102701 - Wayside Radio Techs
Line 1 Run Number GSSI’s = 1001**
Where as ** is the run number
Aurora
Was monitoring Wilson 423.3625, tried switching to Finch as transmissions were active, nothing there except tech GSSI 102701
Aurora
Was monitoring as the rush hour wound down, heard lots of activity on 100002 of trains returning to the yard. Talk of turning on the train wash. Shuttling trains between tracks. Assigning tracks to returning trains.
It was a great opportunity to hear techs cycling through tests with TTC control so we could identify some of the functionality. Tech cycled through calling in via their colour coded RTT system. (Green, Yellow, Red) All responses went back to the train’s run GSSI. In this case 100136.
They did talk about a spot north of York Mills where several trains had lost signal and “froze.” Tech identified low RF in the area as they passed through but said his train did not go offline.
Tech asked control to test the fallback system but control radio tech said he didn’t want to do that because it would force all the other trains into fallback.
HiVolt
Toronto, Canada
Yeah, I can only pick up Finch unfortunately. I have a machine set up at work which is near Greenwood Yard and pick up great signal there. Until they switch Line 2 to this, I've only heard the regular stuff on that freq.
HiVolt
Toronto, Canada
I think I just heard a Line 4 (Sheppard Line) Line call on 100040. I think that makes sense since 100010 is Line 1, and 100040 is Line 4.
Aurora
Also noticing that the 60002 GSSI is active on Red Alarms for portables only. Have heard bus and train red alarms (all false) show up in different GSSI allocations.
HiVolt
Toronto, Canada
I actually just heard a Red Alarm (in error) from a Wilson division bus. Maybe its one of those old Orions that still don't have VISION and have portable TETRAs.
HiVolt
Toronto, Canada
Wow, that Malvern antenna is really bad. A brief, maybe 15 minute wet snow event, nothing stuck on the ground, barely a trace on the roofs of cars, and the signal drops by 20db and is spewing decoding errors big time.
Rain doesn't affect it. Just snow.
DRL-XM43
Durham Region
From Malvern, these are the system auto-populated LCN the tg are manual input from where I could find them, they may not be accurate. There are a few more LCN than the last time. I have input "Unknown"... awaiting any further input from anyone. Thank you. "true" is just input from the system confirming activity on The LCN.
0;302;2013;;0;True (Private)
60002;302;2013;Red Alarm ;0;True
101001;302;2013;Unknown;0;True
101007;302;2013;Unknown;0;True
101011;302;2013;Surface Ch. 1;0;True
101012;302;2013;Surface Ch. 2 Wheel Trans;0;True
101013;302;2013;Surface Ch. 3;0;True
101018;302;2013;Unknown;0;True
101101;302;2013;Wayside Signal Maintainers;0;True
101114;302;2013;Wayside Station Desk;0;True
101117;302;2013;Janitors;0;True
101132;302;2013;Wayside;0;True
101133;302;2013;Unknown;0;True
101143;302;2013;Unknown;0;True
101154;302;2013;Russell carhouse;0;True
101155;302;2013;Leslie Carhouse;0;True
101158;302;2013;Unknown;0;True
101159;302;2013;Mount Dennis Garage;0;True
101162;302;2013;Malvern Garage;0;True
102401;302;2013;Wayside Work Crews;0;True
102402;302;2013;Unknown;0;True
102404;302;2013;Unknown;0;True
102701;302;2013;Wayside Radio Techs;0;True
102702;302;2013;Unknown;0;True
102704;302;2013;Wayside Radio Techs;0;True
102706;302;2013;Unknown;0;True
102721;302;2013;Events 3 - Shuttle Desk;0;True
102723;302;2013;YUS Line 1 Tower;0;True
102724;302;2013;Roncy CIS;0;True
102727;302;2013;Streetcar Supervisors;0;True
102728;302;2013;Streetcar Supervisors;0;True
102732;302;2013;Bloor-Danforth Line 2 Tower;0;True
102733;302;2013;Unknown;0;True
102734;302;2013;Bus Operations;0;True
131032;302;2013;Unknown;0;True
131071;302;2013;Transit Control to Bus PA;0;True
131074;302;2013;Transit Control to Bus PA;0;True
131442;302;2013;Unknown;0;True
131205;302;2013;Unknown;0;True
mciupa
Moderator
Saw that we had a duplicate of Radio Tech and Subway Shuttle and made the correction.
Then I looked over the Groups list I have without ID:
  • 60101
  • 100141
  • 100136
  • 101007
  • 101148
Throwing these out there if anyone has any ideas.
HiVolt
Toronto, Canada
I havent been logging for a while, but today i turned it on and saw a new group 100020, which is Line2 Call for Bloor Danforth Subway.
I guess they are getting tetra radios now too?
HiVolt
Toronto, Canada
They must be, I just heard Run 256 on Line 2, TG 100256, and Run 257 TG 100257, as well as a Line 2 PA call 100029.
This is on Birchmount tower, have not heard anything from Line 2 on Malvern or Finch.
HiVolt
Toronto, Canada
I've logged quite a bit of Line 2 trains over the past few days. It's whatever happens to pass on the open cut from Victoria Park to Warden.
I guess it's fair to say that 1002xx is for all the Line 2 run numbers.
100253 Run 253
100254 Run 254
100255 Run 255
100256 Run 256
100257 Run 257
100258 Run 258
100259 Run 259
100260 Run 260
100263 Run 263
100264 Run 264
100265 Run 265
100266 Run 266
100267 Run 267
100268 Run 268
100270 Run 270
100271 Run 271
100272 Run 272
100273 Run 273
100274 Run 274
100275 Run 275
100277 Run 277
100298 Run 298
HiVolt
Toronto, Canada
100204 Run 204
100210 Run 210
100211 Run 211
100221 Run 221
100251 Run 251
101155 Birchmount Garage
100003 Greenwood Yard
