Torrington PD
WeatherCT
Torrington, CT
Anyone having issues with Torrington PD frequency? I am either getting silence or just noise on my scanner.
WeatherCT
Torrington, CT
Yea, I have that frequency and nac, oddly enough this is within last few days, was fine a while ago but I notice its fine on a broadcastify feed to some extent, it seems like the transmissions are only one sided
55engine
Hartford County area
Ex girlfriend lives in Torrington I had my Apx 7000 with me and I was picking up both sides really good so I don't know I live in Bristol I still pick them up
WeatherCT
Torrington, CT
You can really say I am perplexed since this issue comes and goes for me, but sometimes I will hear one transmission and others I will just hear silence when they key up.
Mork
Connecticut
Which scanner are you using? I copy them without any problem in New Hartford.
WeatherCT
Torrington, CT
OK now are you holding on 152.3225 (and not the input frequency) and not in scan or priority mode?
Affirmative. Occasionally time to time I will just hear noise or one part of the transmission, but mostly just silence when keyed up.
Mork
Connecticut
Sounds like it's not decoding the P25 digital signal properly. None of my Unidens do that. Look for a P25 adjustment or try the attenuator in case you have too much signal.
WeatherCT
Torrington, CT
Oddly enough, I fidget around with the antenna and its picking up transmissions more dependent how on my antenna and placement of the scanner.
