Tower 420?
PRO2006
I am logging tower 420. I don't see it here:
http://www.radioreference.com/modules.php?name=RR&sid=2471
Very strong here in Woodland Park, pick up with duckie. Not a lot of activity on the tower.
Tower Info:
FileVersion:2
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 1e3
System Name :
WACN : bee00
Tower Number (Decimal): 420
Tower Number (Hex) : T0414
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) : WPYN817
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth
0,851.00625,0.00625,-45.00000,"Confirmed",0.00625
1,762.00625,0.00625,30.00000,"Confirmed",0.00625
-Frequencies
#Format: Channel,Usage,Frequency
"0-98d","i",866.28750
"0-a07","av",867.05000
"0-a65","av",867.63750
"0-b09","a",868.66250
"0-b15","c",868.73750
-Neighbors
#Format: TowerID,TowerIDHex,Channel,Frequency,Tower Name
412,"T040C","0-b11",868.71250,""
415,"T040F","0-a6b",867.67500,""
419,"T0413","0-54d",859.48750,""
jimmnn
Colorado
Notice it's system 1E3 on your logging, that would be Badger Mtn part of the El Paso County P-25 system and not part of the DTRS, attached is my file logged soon after it went on the air Dec 18, 2006. Even though DTRS has a site (145) located on Badger as well.
It should be included in the El Paso / Teller County database lists.
Good catch.
Jim<
PRO2006
Good catch.
Jim<
Is it really on Badger mountain? Seems way too strong to be from Badger mountain unless it has a lot more power or different configuration than the DTRS on Badger.
I have to use the yagi to get Badger DTRS most of the time.
And next time I will search the forum first! I found the references to the tower 420.
Bill
PRO2006
Bill
Just took a little drive west. 420 is on Badger mountain, just a lot stronger than the DTRS there for some reason.
