Tower install
NP3Z
Utuado,Puerto Rico
Hi .Im about to install in my house a 10ft tower.My main problem is that the surface were im going to mount my tower is completly flat i can not dig any holes in it to make a cement base or something like that.What other thing can i do to secure the tower instead of the concrete base ? or i can make a concrete base in the first section of the tower without making a hole? many thanks , waiting on your advices..HectOr NP4R
Jim41
Antenna tower mounting
Will the tower be installed "in" your house or "at" your house?
Describe the "flat mounting surface." Is it soil, rock, concrete, wooden deck, roof, etc.?
Jim41
ab5r
Your said "10 ft" tower. Is that all, of just the bottom section. Clarify please?
Ten Feet tall
If this is just one tower piece, get three L-brackets, a masonry drill bit, and some masonry screws. Set the tower on the cement pad, mount the L-brackets to the tower and the cement pad. I would be totally comfortable with this supporting one ten foot section of tower. If you're leery, then do all I've said, climb halfway up the tower, and hang off the side. If it don't move from your weight, whatever you put on it isn't gonna pull it down.
Project25_MASTR
Millennial Graying OBT Guy
Texas
They'll pop if you do that from the top of the section, ask me how I know...
