The range frequencies for Townsend Range are:
119.225 – Townsend Range/Coastal MOA
228.400 – Townsend Range/Coastal MOA
252.900 – Townsend Range/Coastal MOA
226.975 – Townsend Range/Coastal MOA
269.350 – Coastal MOA
228.400 and 252.900 are the most frequently used with 228.400 being the primary range check-in frequency. Townsend Range is operated by the USMC and primarily used by the F/A-18s and F-35s at MCAS Beaufort. It is also used by F-16s from Shaw AFB and Joint Base McEntire, A-10s from Moody AFB, and other aircraft from throughout the region. I have a page on my blog that lists frequencies that might be used for air-to-air traffic between the aircraft using the range and some of the callsigns they use:
MilAir
I split time between Savannah and Brunswick and listen from both locations, so if you're in Wayne County you should be able to hear some of the same things I do. I do a monthly post on my blog of what I've heard the previous month and the one for June is at
Coastal Georgia Military Monitoring Recap; June 2019
You can take a look at it and it will give you an idea of what's out there to hear MilCom-wise in Coastal Georgia.
Mac McCormick III, KF4LMT
Savannah/Brunswick, GA
