TP9800/9900 KVL cable
pewpew45
Looking to use my Motorola KVL4000 to keyload my TP9800 radio. Can someone direct me in the proper direction of what cables I would need. I would think a hirose to ethernet adapter would work, but not sure and this along with a simple programming cable for the radio seems to be impossible for me to find info on.
Any help would be greatly appreciated.
W2GLD
Michigan
You need the standard programming cable along with the TPA-SV-020 adapter box and associated cables, including the USB power injector for use with the KVL4000 and serial adapter cables to interconnect from the TPA-SV-020 adapter box to the radio programming cable. It’s an expensive venture, approximately $700 in parts.
pewpew45
It’s a start. Figured it was going to cost a bit but need it. Thank you very much for the reply and info
