TPT on EFJ5100
jfab
Broomfield/Aurora, CO
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.1.1; en-us; EVO Build/JRO03C) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Hello. While browsing around my PCConfig software tonight I noticed there was an option to enable a talk permit tone. I selected it but there was no TPT when I keyed up. Does anyone have any experience with programming this TPT or is this only available on trunked systems? Is there a way to "hack" it like you can on the HT1000 and XTS5000?
Thanks!
We used it on our 5100's, but that was on a trunked system. It got annoying, so we shut it off.
I'm pretty sure it's a trunk thing anyway. It's telling you that the central controller has assignrd a channel, and you radio is ready. That info doesn't happen on a conventional system.
grem467
Houston, TX
The EFJ 51xx/53xx/VP600 radios also allow you to program the TPT on conventional as well as trunking.
jfab
Anyone with any ideas?
box23
State of Superior
Do you know how I would go about programming/activating that?
Thanks!
You already found it, but on the second page of the per system settings, click the check box next to "Talk Permit Tone".
In the "Duration" box set a reasonable delay time, I have mine set to 0.2 seconds.
Now if you are using multiple systems, make sure under your Zone/Channel assignments that you are using the correct system.
Quick explanation of how it works, which differs from trunking protocols:
When the PTT is pushed the radio starts transmitting but without audio. On analog the MDC Pre ID will transmit if programmed as such during this timeframe. If set for a relatively long duration the radio will be transmitting for the entire time, but the microphone is not active. Once the time is up the radio emits the TPT and activates the microphone. On digital it works the same, obviously without transmitting any programmed MDC.
The reason I bring this up is that if you accidentally have the duration set really long then when you tried it you could have saw it transmitting and dismissed it as not working without waiting for the full "Duration" time. I'm assuming that's not the case, but a possible option.
I have 4 radios with a few channels set up this way just for fun and they all work fine.
Hopefully that will help some.
