TR-5820-K programminmg
RadioChief55
I programmed my Kenwood TR-5820-K and I can't get one channel to receive. I have it posted below, it a UHF P-25 channel. I have P-25 channels others programmed and the settings are the same and they work fine.
Picture 1 shows channels 1,2 and 3. Channel 2 is the one that isn't working, channels 1 and 3 work fine.
Pictures 2 and 3 are the channel that isn't receiving and pictures 4 and 5 are one that works.
I'm programming with KPG-112ND.
Any help would be appreciated.
RadioChief55
This picture is from the data base, I do realize I have it programmed with the same receive and transmit frequencies , I did have it with the input frequencies and it made no difference.
kd4efm
EL98 Florida
Try RX nac F7E. Let me know.
If they are running encryption, you will hear it.
Nothing you can do about it if they are.
Sent from my SM-G935P using Tapatalk
RadioChief55
They are in the clear. I'll give it a try and let you know. Thanks
kd4efm
EL98 Florida
F7E is like open no code in p25, if it opens and you're hearing chatter, then the original nac code is not 315, it was changed. Need to decode it or find out the new nac.
RadioChief55
I put in NAC F7E and still nothing. I read a Moto radio that receives and is running the same channel info and NAC 312 (as I had/have in) . The only thing different with that program is that (Itinerant channel frequency) was checked and all the other P-25 channels didn't have that box checked. I don't know if that is the problem, I didn't see that on the Kenwood CPS. Any thoughts?
RadioChief55
Also, when that jurisdiction talks, I'll get it on the scanner and on the radio I get nothing but the signal shows strong and the light is lit indication the channel is busy. I took the Nac out and ran it CSQ and heard the digital noise when they were talking.
kd4efm
EL98 Florida
I will take a look in a bit, out on service calls right now.
bc780l
Check the talk group. 1 is the default, but others may be in use.
RadioChief55
They are all programmed as NONE, I tried to set it to one and it gives me an error. This is the weirdest thing.
bc780l
Just to verify, you added TG 1 to the TG List (Edit>P25>TG List)?
Might also not check the Talkgroup Strapped box.
Your Moto read should show a TG for reference, too...
H9+8remDc2kQAAAAAElFTkSuQmCCAA==
RadioChief55
That's not an option. The drop down does nothing and if I manually put a 1 in that spot, I get the below message.
kd4efm
EL98 Florida
that is in the p25 menu, not channel edit. add the tg to the list. line 1 = tg 1.
efm
RadioChief55
Is this the place I should be looking? Nothing is set upin here and the other P25 channels work. Thanks.
RadioChief55
Still no luck getting this channel to work. Some configurations work in my Motorola XTL 2000 but not the Kenwood TR-5820-K.
kd4efm
EL98 Florida
2.21 is out. Maybe a bug in 2.1
RadioChief55
OK, I'll have to figure out how to do a firm ware update. All the other P-25 systems work. It's strange. Thanks for the help.
RadioChief55
Looks like I'm giving up with this radio trying to get this channel working. It's a town we work with a lot, I really wish I could figure this out. But I've wasted to much time on it. I'll have to keep my Moto XTS 2500 with me to hear them. I really liked this Kenwood radio, but it just wont do what I need. :/
