BillH1
Has anyone used the tram 1400 base antenna. I am looking to hook it up to a scanner to replace a centerfire antenna. 90% of what I listen to is VHF between 150 and 174 Mhz, and the tram is supposed to have 6db gain between 136 and 174 Mhz. I live in a fringe area, but am currently receiving what I want to receive, but not very well. Most of the time i can't make out what is being said. I'm not real concerned with switching from a VHF/UHF antenna to a dedicated VHF antenna because most UHF I do listen to is high powered and local to me. Im open to recommendations as well, I just don't want to spend a small fortune. The VHF frequencies I listen to are about 30 + miles away and my antenna is about 33 Ft in the air, and like I said, i'm receiving them, but not very well. Would swapping to a high gain VHF antenna help? If im not mistaken the antenna I am currently using is unity gain, but i'm not sure.
This is the antenna i'm looking to replace, opinions please.
https://centerfireantenna.com/antenna-menu/vhfuhf-multi-band/
Here is the tram
https://www.walmart.com/ip/Tram-140...F-135MHz-174MHz-Base-Station-Antenna/51629597
Thank you,
Bill
Here is the tram
Thank you,
Bill
