firebus29
My employer is installing an Icom F-5061 (VHF-hi transceiver) in my newly assigned vehicle. I wish to also install my personal Regency 780 XL. This scanner will be used to monitor VHF-hi and UHF. I can have no add-on antennas on the vehicle other than the one for the transceiver. I have read the sticky about multiple receivers using one antenna, but it does not address my situation.
Is it possible for me to split the music radio antenna with the scanner, and if so, what quality of reception would that produce? Would my attempt to split the transceiver antenna with the scanner cause a power surge to the scanner, or some other expensive disaster? I am open to any solution which will solve my problem.
Thanks for your help.
