Transfer data
fxdscon
¯\_(ツ)_/¯
Is there a way to transfer data from my 106 to my 197. Thanks
Just download the data from the 106 into Win500, and then upload that data into the 197.
krokus
Southeastern Michigan
Keep in mind that you will lose the programming of the scanner on the receiving side of the cloning. Using your preferred programming software allows you to keep a copy of the configuration, to re-load, if wanted.
Sent via Tapatalk
kc4jgc
Virginia Beach, VA
However, if you were to change the recieving scanner to an empty virtual scanner before cloning, you can keep BOTH configurations. All you need to do is switch between the two, if needed.
