Baofeng Transferring analog data from UV-32 to DM-32
KI4LIV
Melbourne, FL
Anyone have any suggestions on the easiest way to transfer analog frequency data from a UV-32 to a DM-32? With the aid of CPS and Chirp I've got my UV-32 setup exactly how I want it - now I want to transfer the data over to the DM-32 as a baseline load before using CPS to hand key in all the DMR data.
Suggestions are greatly appreciated!
chief21
Western NC (Summer); Tampa Bay FL (Winter)
I don't know for sure, but I would suspect that the file structures of the two radios, one being analog-only and one being analog/DMR, might be quite different. Are the filename extensions the same?
I suppose that you could import each type to Excel as .csv's and cut and paste using the DM32 file as an example for the proper location(s) of the analog data.
sefrischling
Public Information Officer
New London, CT
The two radios are completely different. They share a case, but internally they are not the same radio in any way. You cannot share files from one radio to the other.
