TRX-1: transferring frequencies to scanner
dougp_nyc
Could someone please describe the process of transferring frequencies and talkgroup objects that I've programmed into EZ Scan (in anticipation of receiving my new TRX-1) into the scanner, The update of the CPU, DSP and library is pretty straightforward but I'm not sure on how to get what I've put into EZ Scan into the scanner.
TAbirdman
MO
under Scanner/SD card pull down menu, select Copy configuration TO scanner memory/SD card
scosgt
And once you have backed up the software, it is a good idea to always format the SD card and then copy everything in.
