Transmission ID?
hockeyref2
Northern MI
Hello,
Hopefully this is posted in the proper location..
I have some repeaters in the UHF business band (451/456 mhz). I am getting a transmission of some sort coming over the input side of one of the repeaters. It does not appear to have CTCSS/DCS tone and so repeater does not repeat it..... Of course it will interfere with users when they transmit on that repeater however....
It usually lasts a second or so, and comes at 'random' intervals. Sometimes its hours,sometimes its every few minutes. Any idea on what this is? Screenshot from SDR# and a .wav file in a .zip file...
There is nothing that I can see in current FCC licenses that makes any sense..
Thanks for your thoughts and ideas!
  • The Noise.zip
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Sounds like a differential gps transmitter used in land surveying. Basically, these survey companies buy a box that comes with 10-16 channels and a note saying "get licensed". Very few get licensed. So, you end up chasing these guys around. I find that if you DF to their transmitter, it is usually a gps antenna on a tripod with a differential box and a few car/deep cycle batteries. Typically, there is no one near the box and if you disconnect power, they show up fast. TT
My cousin ran into one of those, finally got in touch with the owner who just changed channels.
Local Goodwill has a Ritron alert system with a canned message about 'customer assistance needed at the fitting rooms'.
I went in and asked if they had a license, got the deer in the headlight look.
hockeyref2
Northern MI
Thanks! I wonder if its for a gas well or something? I found one expired license using the '6.1 meter rule' but most of their locations are 150+ miles away. A few other 'local' licenses but they are just narrowband FM...
I've never done RDF, nor have the gear to do it... I may end up changing frequencies... Bit of a pain with 100+ subscribers to reprogram, plus repeater, probably just get a new duplexer... but at least I have a license for it already.
TampaTyron
Phoenix, AZ
You can take duplexer to a radio shop and have them retune it for you. Should not be more than an hour or so of labor. Certainly less expensive than buy and learning RDF. TT
