Transmit Frequeny/Recieve Frequency
RadioHead98
When looking at Frequency Listings for Law Enforcement Channels..How can you tell the difference in other words ...which is the Recieve and Is the Input Frequency the Transmit?...What are the Send code and the Receive Code on a listing? Thanks in advance
jerk
jerkville
For what County, and all you really need is the receive frequency and PL tones. You will receive everything just fine.
RadioHead98
Jefferson County Sheriff...Theere are 4 Frequencis listed...under Jefferson County Law Enforcement..Thanks What are PL tones?
Don_Burke
Southeastern Virginia
I see five frequencies.
There are four repeaters:
453.67500
453.97500
453.40000
460.20000
There is one simplex frequency:
458.33750
Using the PL will knock down some of the noise and interference. Is your scanner capable of using PL tones?
jerk
jerkville
It's listed in the database correctly, in fact all the Law Enforcement is accurate for Jefferson County. Just ignore anything that says input.
I don't monitor the system all that often, so I'm not sure how active the last two are.
SHERIFF METRO 453.6750 CTCSS 162.2Hz
SHERIFF F-2 453.9750 CTCSS 162.2Hz
SHERIFF F-3 453.4000 CTCSS 162.2Hz
SHERIFF F-4 460.2000 CTCSS 162.2Hz
BigDog-911
Kentucky
I don't monitor the system all that often, so I'm sure how active the last two are.
The last 2 are not active as far as I know. I have never heard anything on them unless they are simplex around the courthouse.
jerk
jerkville
I concur, you are closer and hear them more than I do. But I was in Louisville or near it all day. I just heard Metro and F-2 being active.
I need to go sit by the Courthouse(s) as I have some federal frequencies I'd like to narrow down.
RadioHead98
453.67500
453.97500
453.40000
460.20000
458.33750
I do not know..what is a simplex frequency?are the repeaters Transmit and receive frequencies?In other words are the repeater frequencies both transmit and recieve?
RadioHead98
If these are UHF ,...what is the 162.2Hz?
jerk
jerkville
UHF and 162.2 is the Tone Squelch aka Private Line by Motorola, Channel Guard is what GE Ma/Com calls it.
What type of scanner do you have and are you trying to program?
Because it's sounding like you want to program a radio. I would suggest spending time in the manual and on the Wiki here learning some of the basic details, it will make things a little clearer.
