Transmit inhib with CHIRP Software
teufler
ST PETERS, MISSOURI
CHIRP says there is a transmit inhib setting for "scanner frequencies" or frequencies we don't want to key up on. Where is this setting?
KC9HI
This ability depends on the radio model (CHIRP can't make a radio do something it isn't capable of doing). If the radio that you are programming is capable of having TX inhibited and the developer added support for it, then the "off" setting would be available for Duplex.
See the CHIRP Programming Guides and Examples in section 6 of this Miklor webpage.
Jim KC9HI
jk77
Ohio
There's not a single switch. It is doable, but you have to change several settings. I don't remember the exact method, but you can find it on the Chirp site IIRC.
