Transmitting Page via Quik Call 2
N5PFR
I'm in the process of upgrading some HT1250's and CDM's that our volunteer dept uses for rural fire paging and comm's. I need to be able to page out our dept via Quik Call 2 (with voice) after the radios alert to the A-B tones that we use to alert all of our volunteers. I think I have this correct but I'm not positive. I have set up my HT1250 to signal with our A-B tones under the selective call tab. The page goes out and alerts just as it should. The receiving radios alert after the tones. The problem is the following voice transmission. I think I understand this to work as follows... Once I key up the PTT button and the A-B tones go out, I then have to go back to our main fire frequency in order to transmit any voice. Is this correct? I can't see any way to use the selective call mode for anything other than the sending of the A-B tones. If I keep the PTT button keyed, I hear nothing on the alerted radios as I attempt to transmit voice other than a carrier with no voice. I apologize if this has been posted elsewhere. I've read many posts but I'm not certain if I'm setting up the system correctly.
Thanks for the help.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
This should help:
QUIK CALL II DECODING
Signaling ► Quik-Call II System ► Add or create a QCII system
Basic Tab: Call Format should match the tones of your system
Call Alert/Sel Call Tab ► Call Alert Type: Call Alert w/Voice
Call Alert/Sel Call Tab ► Call Alert LED: Optional
Call Alert/Sel Call Tab ► Alert Tone Auto Reset: Unchecked
Auto Reset Timer Type to be Auto w/Carrier Override
Individual ID Tones Tab ► Enter your desired tones
Signaling ► Signaling Configuration ► Call Tone Tag Tab ► Sel Call Tone Tag – Here you can optionallychange the alert tone that the radio sounds when a Selective Call is received.
Signaling ► Signaling Configuration ► Call Tone Tag Tab ► To be Disabled
Conventional Personality ► Select the personality for QCII ► Signaling Tab ► RX Signaling – use dropdown to select the desired QCII system
For Signaling Squelch choose "And" for the radio to always be silent unless an alert is received matching the QCII setup.
For Signaling Squelch choose "Or" for the radio to monitor all radio traffic and alert when a call is received matching the QCII setup.
Controls & Menus ► Programmable Buttons ► Besure to define one of the programmable buttons short press to be Monitor. Pressing Monitor after an alert will return the radio to silent alert mode just like the reset button on a pager.
NOTE: If you want to use the radio like a pager (silent until alerted), create an additional Rx only personality for your QC-II, use the "AND" squelch. Plan to jump to your regular channel to transmit and/or receive. Do not include this channel on your scan lists and don’t set it up to scan or auto scan as scan will interfere with the radio hearing and decoding the tones.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
To add to what @SteveC0625 said, if you're sending tones from a subscriber unit, you'll probably also have to hold down the PTT button while the tones are going out from the radio and then make your voice announcement without releasing the button. Otherwise, if you release the PTT the tones will get sent again the next time you push it (I found that out the hard way once).
N5PFR
I did discover that releasing the PTT button and then pressing again would send the tones a second time. I still cannot transmit voice after the tones have been sent. If I keep the PTT depressed and attempt to send voice, I hear nothing on the receiving radio. That's what I"m still confused about. I have everything set according to Steve's instructions above but still no voice.
N5PFR
Well, problem solved. I am not transmitting audio on the HT1550XLS on any freq! I had not used this radio for a long time and now discover it to be bad. Possibly a mic setting but I'll have to look into it. It's transmitting a good carrier but no voice.
N5PFR
Torn ribbon at internal mic. Not terribly happy with this at all. I'm certain that any replacement front housing will be crazy expensive. It doesn't appear to be something that can be replaced easily. I assume the mic is not available nor is it easy to replace.
jruta
Nj
What about using an external mic?
N5PFR
That's exactly what I'm going to use. I have a generic external mic and it works. Sound is awful but it does work. I'll look for a good microphone so that I can still use this radio. I'm not very good with external mics though. I worked for 32 years as a firefighter and I can't tell you how many times I used mine as a slinky. We used the ruggedized lime green mics from Motorola. They will take a beating!
