Transmitting/Receiving with SWR meter inline
TxDoc
TEXAS
Will it hurt to transmit with an SWR meter hooked up? WILL out affect reception?
Sent from my XT1254 using Tapatalk
jonwienke
More Info Coming Soon!
VA
It won't hurt anything in the sense of damaging your radio, coax, or antenna. But it will cause a small signal loss, typically under 1dB (depending on the meter and additional adapters or patch cables needed to add it into your signal path). In most cases this will not be noticeable. But you'll want to minimize the length of additional cable and the number of adapters needed to connect the meter between the radio and antenna.
TxDoc
TEXAS
THANK YOU for that lightning fast very clear reply, jonwienkw.
