Travis AFB: No audio.
RolnCode3
Sacramento/Bay Area, CA
Travis AFB: Having problems. I pick up the CC, get 99% decode. I see it switch to voice channels, and display talkgroup IDs. However, I get absolutely NO audio. It just goes to the talkgroup, kind of flickers (almost like checking priority channels...which is deselected). I have tested the scanner on Marin's system, so I know I get digital just fine. Any ideas? I'll post the file just in case someone wants to look at it. It's the first bank. BTW- I can only get this when mobile, so I can't check on any fixes until I go down that way again.
I've got it set up like this:
Both MOT 3600CC and MOT 9600 CC have Multi Table selected. Then, extended tables is set up as below.
Ch Lo Ch Hi Base Offset Step
380 541 482.000 380 12.5
542 759 488.000 542 12.5
WayneH
Forums Veteran
Super Moderator
Your master site
Bill, you have your tables programmed for either MERA or San Mateo. Way off there guy. Not 480s.
-Wayne
northzone
Northern California
Wayne, you are sharp. I have a lot of respect for your input (and Bills' also). Thanks to both of you for your continued input. Gary
PS: anybody getting anything from the new Davis system?
selgaran
CM98dn
I've been told that they're going to start moving users (fire, to begin with, I think) onto the system by the end of the month.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
You got that right Gary, Wayne helped me with a similar problem 17 months ago when I first programmed a 400 system in a Pro-96, "set the table" fixed the problem. But by his avatar, Wayne rejuvenates his brain every 7 seconds. :lol:
WayneH
Forums Veteran
Super Moderator
Your master site
WayneH
Forums Veteran
Super Moderator
Your master site
I split off the City of Davis messages to their own thread. Please reply there. Thanks!
-Wayne
