Travis Plane Spotting / 8/26/2005
b52hbuff
I went to Travis on 8/26 for a quick bit of plane spotting on a quick stopover to another final destination. I was there from about noon until 5pm. I brought my Pro-96 and my BC-246T. I wanted to bring my BCD-396T, but it was on the FedEx truck and didn't make it before I had to leave.
I admit I'm not really into to writing down all of the details of the stuff I hear. I'm more into verifying the radio traffic. Part of the motivatoin was to get a preview for the upcoming airshow.
My first location was here:
<http://maps.google.com/maps?q=fairfield,+ca&ll=38.241315,-121.977897&spn=0.015786,0.029232&hl=en>
...at Lambrecht Sports Complex.
It was good for watching the planes leaving Rwy 21R. The biggest problems was that it was HOT. There was no shade. Then, I went:
<http://maps.google.com/maps?q=fairfield,+ca&ll=38.241500,-121.939723&spn=0.007893,0.014616&hl=en>
At approximately the point where the line between the shading. There are some trees on the south side of the road that provide shade from the sun.
As I said earlier, I wanted to bring the 396T to see how it'd do on the Travis TRS. It didn't make it, so I had to use my trusty Pro-96. With a Diamond RH-77CCA antenna it managed to pull in the system from the Benicia bridge. I had programmed the radio according to the config on radioreference.com:
http://www.radioreference.com/modules.php?name=TRSDB&sid=2611
The list below contains the TGIDs that were active during my stay. The labels seemed to be appropriate for the traffic I was monitoring.
38448 963 D P.O.L 1
40048 9c7 D Fire Dispatch
48048 bbb D C-5 Blue
48080 bbd D C-5 Gold
48112 bbf D C-5 SUPPLY
48144 bc1 D C-5 Tow 1
48272 bc9 D E.M.S/C.R.S
48304 bcb D T/A
48336 bcd D KC-10 1
51248 c83 D C.E. 5
51312 c87 D C.E. 3
51440 c8f D C.E. 4
54448 d4b D Pax Service 1
54576 d53 D A.T.O.C 2
54640 d57 D A.T.O.C. 3
56048 daf D Transportation
62448 f3f D Ramp (Tower)
I also made a few discoveries...
624 was a rebroadcast of the 349.4 Command Post frequency. It was an analog TGID. All of the other discoveries were digital/P25 voice.
Here is a list of new TGIDs that I identified:
624 Travis Command Post(349.4)
33936 Housekeeping
54512 FleetControl
60944 EMS to Hosp
Here is a list of TGIDs monitored, but not enough information to make a label:
38480 "Phantom 14"
33968
48240
51504 HVAC?
54512 (Some sort of airfield control)
54672 "C-5 Mission Complete"
I also monitored the old analog conventional channels that were listed in Bob Kelty's Monitoring the Military (1991) along with some additions from material from Grove's Military frequency guide. There was no activity. Perhaps they may dust off these radios for the airshow? ;)
While the Pro-96 was kept busy with the BC-246 was scanning the old analog radios mentioned above, the VHF airband and Close Call. The only Close Call hits were the occasional VHF airband from airplanes in the pattern. There was no new information from these close call hits.
Below is a frequency table I found on the web. The 'usual suspects' were active (e.g. Tower, Ground, etc). In addition I heard traffic on:
349.4 AMC Command Post
139.9 (AM) Tower Multi function
294.7 Discrete/Radar Approach
I'll be scrubbing my configs and will post something for the BC-246T, BCD-396T and Pro-96 before the upcoming airshow.
Attachment 5
LOCAL FREQUENCY CHANNELIZATION
CHANNEL (UHF) UHF VHF POSITION
1 335.8 127.55 Clearance Delivery
2 289.4 121.8 Ground Control
3 254.4 120.75 Local Control (Tower)
4 306.9 126.6 Departure Control
5 291.0 126.6 North Approach Control
6 294.7 128.4 Arrival Control
7 322.325 119.9 South Approach Control
8 318.1 N/A Discrete
9 392.0 N/A Discrete
10 N/A N/A Discrete
11 349.4 141.9 Command Post
12 372.2 N/A Pilot to Dispatch, USAF
13 344.6 N/A Pilot to Metro, USAF
14 285.575 N/A Pilot to Dispatch
15 343.6 N/A Discrete
16 379.3 N/A Discrete
17 BLANK BLANK BLANK
18 384.9 116.4 ATIS
19 269.2 N/A Pilot to Metro, SUU
N/A N/A 132.1 Discrete
N/A 239.05 N/A Discrete
N/A 251.125 N/A Discrete
WayneH
Forums Veteran
Super Moderator
Your master site
I knew there was analog activity on that system! I happened to hear 624 last week also, but not enough to get an idea who or what.
-Wayne
b52hbuff
-Wayne
How did you know? Was it something in the datastream?
Also, the audio on 624 is _very_ weak....
WayneH
Forums Veteran
Super Moderator
Your master site
You don't notice the difference in audio? Especially patching to an AM frequency. Guess I just have an ear for it. ;)
-Wayne
b52hbuff
-Wayne
Oh, I can certainly hear it. I was expecting a more 'fancy' answer.
