TRBO CPS 2.0 Clarification
Floridarailfanning
Tennessee
I have some projects coming up later this year and next year which will require CPS 2.0 and I am looking for some clarification. Does CPS 2.0 require you to have a list of serial numbers for all of the radios which need to be programmed?
I may have misinterpreted this, but my understanding is that you have to get a list from MSI which includes the serial numbers for each radio ahead of time. Is this correct, or is that only needed when conducting firmware updates? Thanks.
EWC_BDN
in RM you have to add the SN to the software to read the radio. You are able add them from the list MSI provides as an excel sheet, but you can just type the SN in if you want. Or scan the barcodes. This is annoying of course, but in RM it makes sense. In RM you would highlight all the radios you've added and then hit write. you could then plug each radio in, it would detect what radio you plugged in an execute your write job to that radio.
Unless you use Cap max or OTAP you won't need to use RM. I personally don't ever use it.
