Trenton PD
N9JIG
Sheriff
Moderator
Far NW Valley
Have a friend trying to hear Trenton PD. I understand they were going to move away from the 800 mHz. VSLEP system onto a UHF system but cannot find any listing for them, either in the RR database or the FCC.
Any ideas? Are they still on VSLEP 800, the County system, their own UHF channels?
Skypilot007
Medford, NJ
I thought I remembered reading that they were switching to a Kenwood NXDN type system. I don't if that ever happened.
richee2000
Banned
the data base still shows them on 800 mhz.is someone going to update with their new UHF system?
Skypilot007
Medford, NJ
That sure would be nice just for informational purposes even if they can not be monitored. What's the big secrete?
richee2000
Banned
so, are we now keeping certain municipal police dispatch channels a secret??? and if so, WHY?
richee2000
Banned
can ANYONE please post the NEW UHF Trenton PD Freq???
cash082
Wall Township, NJ
Since nobody is saying what they are using..............
I was looking at license KED796...quite a bit of UHF stuff in there that's not in the DB.
How about these frequencies...
460.6000
460.575
110w licensed on each...and it's UHF...not seeing it anywhere in the db relating to Trenton.
I am not from the area, I'll attempt to monitor/close call when I'm out there and do some analysis.
Not sure why this is such a secret.
Time to do some discovery...this find is just a random guess.
https://www.radioreference.com/apps/db/?fccCallsign=KED796&s=cl
Also seeing WIJ719 at 506.9125 (40w) / 509.9125 (10w) w/ 20K0F3E
CM1
Central, NJ
Was just poking around some, and came across a trunking system for Trenton, NJ under WPGP231:
ULS License - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Trunked License - WPGP231 - TRENTON, CITY OF
(some frequencies show "D" (deleted) possibly from the older analog VSLEP system ?). I didn't go though all the frequencies listed, but it looks like most have emissions designated as: 20K0F3E, 15K0F2D. I also did NOT get any to try and monitor this system (and am not even sure I'm close enough pick them up).
Be curious to know if this turns up anything at all.
robbinsj2
Bridgewater, NJ
It's well established, through media not to mention other posts here, that they're on a commercial UHF system. I haven't heard which system, if I still lived in the area and still had the time which I used to then I might be interested enough to chase it down.
For others, you can start with MPS Communications (listed as the point of contact on the referenced old 800 license) and also research the contract which the city undoubtedly has for this service -- the contract must be public record, no?
Or hang out where PD units frequently transmit and close call/ signal stalk it.
Jim
richee2000
Banned
septa3371csx1 knows where they are, but he will not reveal it.
carbineone
461.5875 462.0375 462.050 462.075 462.1375 462.300 462.3875 463.2250 463.24375-Control Channel 463.3250 463.56875-Control Channel 463.7375 463.7875 464.2125 464.3625 464.8125
WQSA690
richee2000
Banned
16 channel Trunk system... Encrypted?
carbineone
I had a remote scanner before to monitor activity only but I do not have it as of January. Best I can tell at that time it was NXDN unencrypted with 2 or 3 sites. Hopefully with the freqs you can all figure it out now.
richee2000
Banned
thanks for sharing! , and not keeping this a secret , (as others have done)... please update the database
RadioDitch
Field Operations Member
Not Where You Think
Should be NXDN, no encryption on dispatch/patrol. There is a password protected, privately hosted live feed still by another individual outside the city.
