Syncopations
Hears voices in my head.
So I have a tri-chemistry charger, "CH-104560-026 Rev A" with Date Code "1608". The bottom white box shows 39973 Rev C, 061AF. When I put my battery(NiCD) in to charge, the charger immediately goes into to "Fault" mode(rapid red light flashes). When I place the same battery into a gang charger, it'll show "Rapid Charge" then "Top-off" then "Ready," as expected.
All DIP switches and jumpers are in the default position, as sent from the mothership.
I placed a known, good working, battery in the charger in question, and it goes straights to "Fault." I removed the cup, and replaced it with a cup from a 5-pin cup for a P5500. When I put the P5500 battery in there, it went to "Fault" again. So no matter what battery I put into this charger, it goes to "Fault."
Does anyone have any ideas as to what the problem could be?
