Trialling new scanner on stream(GRE PSR500)
longreach
Southern Tablelands NSW Australia
Hi all,
Im trailling a GRE PSR500 on my stream, wondering how it sounds via your feedback.
I am not currently running tags at this time due to problems with the stream computers USB (is only usb1.1 and wont run USB and mouse at the same time), upgrade coming soon.
I formally ran a Pro97 but the volume levels seemed all over the place. the audio boost feature on the PSR500 has sorted that out i feel.
It may be fairly quiet at this time of writing (610am AEST) but should pick up in the next 2-3 hours.
Let me know what you think (i know about the hum and cant locate it at this time)
cheers
Matt
DigitalMDX
Puget Sound, Washington
Feed
The stream sounds good from here. Good audio levels and clear sound.
The hum isn't all that bad. If you have the scanner power supply plugged into the same surge suppressor as the PC you might try plugging the scanner into a different power outlet than what the PC is plugged into. Also you could try a choke on the power cable for the scanner, but all in all the hum isn't that bad.
Jay
