Tricking RPM for out of band
k4do
Some time ago I modified a motorola file.I had to copy the entire program then convert it to hex, then search for the string I was looking to change. The more difficul part was figuring the checksum. It worked. Maybe I will have to try that with RPM.
k4do
found a sc file for you also might want to look around a groups.io group called ge-orion lots of info on them there
Interesting. I did something nearly identical except I used 920 3 times. There is transmit and receive that needs to be changed. I can see shifting all but tx must go up and rx must go down. Thanks for your post
merlin
DN32su
If you have to hack the hex binary data, a program I use is 'HEXEDIT'. It will calculate checsums for you.
Used it hacking a Delta SX and could do anything the radio is capable of.
I know moving high split Orions to 2 meter may need tweaks on the PLL. Also a bit hard on PA with heating but reducing power level is the easy workaround for that. The 900 Mhz radios use the Mitsubishi module for PA, don't know how far out of band they will work.
k4do
Thanks for the heads up. I have used Hexedit successfully some time ago. memory decreases with age.
