Trouble programming Pd355
roblow
Hi All,
I have the Hytera CPS V1.04.04.012.EM5 and this works on 2 of my pd365 radios but when I try and program this pd355 I get an error (model doesn't match)
the radio serial number is : 1449d0834 the firmware is : s1.01.02..005 baseband is:v2.01.01c4
Any ideas or help would be much appreciated
Regards
Rob. :)
dazey77
Can you read the PD355, modify the file and write it back to the radio? Not sure if you are trying to load a 365 file to a 355? (that won't work). You can export channels and contacts from the 365 files to text files, read the 355 and then import the channels and contacts from the text files if that helps.
roblow
hi thanks for the reply :)
when I try and read the radio it errors and says model doesn't match so I cant read the radio at all
Regards
Rob.
dazey77
Ok, that is a bit weird. Is there any chance the radio is from a different region (not europe)? Can you try a later CPS?
Its free software and places like hamdigitaal.nl have it for download.
