Trouble Programming Somerset County
firecentral
Im having quite a problem programming this system using win96 there are 2 different base frequencies with this system can someone show me step by step how to properly program this system thanks
W2SJW
Senior Member
Northwest NJ
Here you go, and it's really simple -
#1 - Make sure the fleet map & table settings are as seen in picture #1, then push the 'extended tables' button.
#2 - Make your extended tables look like mine, and you'll be good to go (there are actually 3)...
firecentral
Thanks!!!
Works Great Now Thanks For The Presentation... Now Can U Do The Same For The Franklin Twp System Forgot To add That Thanxs
W2SJW
Senior Member
Northwest NJ
Yep - picture #1 stays the same, and the offset tables should be as so:
CH Lo__CH Hi__Base Freq__Offset__Step
380____599_____471.0000___380____12.5
600____759_____477.0000___600____12.5
