Trouble receiving Prestonsburg, KY PD on 155.730
kas1263
Boons Camp, KY
I am having trouble receiving Prestonsburg Police Department, Prestonsburg, KY, frequency 155.730. I use FreeScan and see that there are two entries for the same frequency. The differences are one has None in the tone entry and Digital in the Audio type. The other entry has 118.8Hz in the Tone entry and Analog in the Audio Type. The entry with the Digital Only entry seems like it tries to broadcast but just can’t seem to lock in. The other entry sounds like the squelch is on too much. Any suggestions? I am using a BCD996P2.
tvengr
Well Known Member
Baltimore County, MD
If you look at the digital frequency with the 855 NAC, the mode column says P25E. The capital E means that it is fully encrypted and you will not be able to receive it on any scanner. You will be able to receive the one with the 118.8 PL if they still use it.
Frequency License Type Tone Alpha Tag Description Mode Tag
155.73000 WNQG239 RM855 NACPburg PD 1Prestonburg Police P25E Law Dispatch
155.08500 WNFC405 RM118.8 PLPburg 911 DPrestonburg 911 FMN Multi-Dispatch
155.73000 WNQG239 RM118.8 PLPburg PD 1 DPrestonburg Police FMN Law Dispatch
