racin06
GRE sent me a new front faceplate to replace my old one in which the paint was rubbing off. However, I'm having trouble removing the old faceplate The primary board moves freely where the bottom and middle screws were removed, but board doesn't seem to budge at the top...where the top screws were removed. I don't see any other screws that must be removed either. How do I remove the primary board?
Also, I see the speaker wire has a connector on the end. Do I have to remove the board against the scanner in order to remove the old speaker wire and install the new?
