Actually I don't know if the saved favorites will show that, but I actually do have them set AFAIK.Looks pretty good.
You haven't set Quick Keys for each Favorites List. (Of course you might be waiting to see if you are the right track before doing so, which you are.) That means they will always be scanned and the only way to turn them off is with a cumbersome keypress sequence.
http://i.imgur.com/gDf65pa.png
Same here as above. Hopefully I have it right:I encourage you to set Location Control to On for your VIPER Favorites List. Otherwise the scanner will probably spend a lot of time trying to monitor sites too far away to receive. With there being some 215 sites and 5 frequencies per site or so, the scanner is going through 1,000 frequencies, which is time consuming and will lead to missed transmissions. You can try it both ways and will see what I mean.
http://i.imgur.com/h5tEX4x.png
I use the GPS device for mobile scanning and consider it almost "essential equipment". Setting the scanner location via keypad/zip code is efficient when the scanner is stationary. When the GPS device is connected, it feeds correct location information to the scanner as the scanner moves around. Very helpful for travel.
FWIW, my typical way of doing things is to use Favorites List only scanning for when I'm at home or a travel destination. When I'm on the road, I'll turn the full database on and let the GPS/Scanner combo do its thing to turn on/off "stuff" as I get in the area.
As Upman said, the setup is pretty easy. The only issue I had and it was my "doing" was the Baud Rate for the port. I use a Virtual Control program with the Baud Rate of 115200. The GPS works on a Baud Rate of 4800. If I forget to change it back, some bad language is involved.
This is exactly what I plan to do! Thanks!
