Trouble with SDRSharp v1.0.0.1732
RedKnight26
This Monday, I finished building my antenna and was super excited to connect to the NOAA 15 satellite. Got set up and opened SDRSharp for the first time... only to find it couldn't detect the NESDR Smart SDR I'm using. I've talked to a friend and installed the current drivers for it through Zadig, and I've ran the install-rtlsdr.dll file, which I've just noticed says "Access is denied. 0 file(s) moved..."
Anyone know what's wrong and how I can fix this?
RedKnight26
You talked about rtlsdr.dll file... not about running the install-rtlsdr.bat ???
can you confirm you do not have usb dongle on the dropdown menu?
I mistyped the file type. It is a batch, not a dll. Also, the dropdown is grayed out
spongella
W. NJ
You might just try reinstalling SDR#. If you don't already have this info on how to do it see the link. I just did the download with no problems. Hope this helps: Quick Start Guide
