Trouble writing VSCAN Folder
fdnyfish
Barnesville, PA
I created a new Vscan folder 10 called TEST 123. When I try to load this folder onto the SD card (prepare for first use), the card writes, but when I put it into the scanner and it boots up, it says nothing to scan, and my six scanlists are not there. It prompt's me to select a bandplan.
If I load my default KB2MXV vScan folder #1, that profile works fine.
What am I doing wrong that I can't load a different folder?
My screenshots are from the Vscan folder 10
fdnyfish
Barnesville, PA
UPDATE:
I went to my "C:\Users\Frank\Documents\WS1095 Digital" folder and renamed folder CDAT_VS.010 to CDAT_VS.001 (after making a backup of my real CDAT_VS.001).
I told EZscan to write the CDAT_VS.001 folder to the SD card, and now it loads correctly in the scanner.
What could be the problem here?
fdnyfish
Barnesville, PA
TROYMAIL, No I did not. I thought that both folders if uploaded would be merged on upload. Didn't realize that you have to select which folder you wanted. I understand that now. Thank You
