Troubles Programming Digital on XTS3000 M1
So I’ve got an old VHF model 1 lying around that I was hoping to put a few new conventional digital frequencies in. Unfortunately, when I open the cps to do this, the option under RX mode for Astro is grayed out, and there is no option menu anywhere for an Astro system like what I’ve seen when I’ve programmed my model II 3000.
Flash code:
900001-080000-2
Are there any other options that need to be enabled in order for the radio to operate on conventional P25 systems?
Thanks!
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Decoding Flashcode: 900001-080000-2 Platform: XTS3000
H15 - ASTRO Data
Q806 - ASTRO IMBE Digital Operation
H35 - Conventional Systems Operation
Q351 - MODAT
4 options included in this flashcode.
Decoded with CS Forums Flashcode Decoder
What firmware and dsp do you have?
W3AXL
RF Engineer
Indiana
Unlike the later Astro25 series, Astro-series radios had separate analog-only and digital-capable firmware and dsp versions. Upgrading firmware on these radios is also a pain and requires a SmartRib.
That being said, I'm fairly certain if the flashcode is correct an analog-only radio will still show options for Astro systems, but just won't transmit or receive P25. Sounds like perhaps a corrupted codeplug?
