Troubles programming ICOM F11 with ICOM Software PLEASE HELP!!!
kylech99
Illinois
I am having issues trying to program an ICOM F11. I have the software on the computer and the cloning cable drivers installed and in working order but it wont detect the radio. The radio is fully charged. I am using the cloning cable that is usb. Please help me!!
N2DLX
Hamilton, NJ
Make sure you set the programming software to use the proper COM port that the cable is currently assigned to. When you use a USB programming cable, the driver sets up a virtual COM port in Windows. The Icom software then needs to know which to use.
To find out which COM port the cable is currently assigned to, go to "Control Panel", open "System", click the "Hardware" tab, then click "Device Manager". With the cable plugged in, you should see "Ports (COM & LPT)" in the list. Under that heading, there should be a COM port for your cable.
stevelton
Also, the simple things are the ones usually overlooked, but, make sure the radio is powered ON!
Steven
