Hi everyone,
I’ve been experimenting with a capacitive soil moisture sensor for a small Arduino-based garden monitoring project, but I’m running into some issues and could use a bit of advice from anyone who’s used these sensors before.
Thanks in advance!
I’d love to get this sensor stable and properly calibrated before integrating it into a full automatic irrigation system.
Setup Details:
- Arduino Uno
- Capacitive Soil Moisture Sensor 5V power supply
- Analog input read through A0 pin
- Displaying data on a serial monitor and OLED
- Soil samples from a few different plants (tested in both dry and wet conditions)
What I’m seeing:
- The analog readings fluctuate even when soil conditions remain constant.
- Calibration drift occurs over time — readings change after a few hours even when soil hasn’t dried.
- I’m unsure how to map the raw ADC values to meaningful moisture percentages (e.g., 0–100%).
- Occasionally, the sensor output seems to “jump” when powered from USB vs. external 5V.
What I’ve tried so far:
- Verified wiring and ensured the sensor’s VCC–GND–AOUT connections are solid.
- Added a 100nF capacitor across the output to smooth noise.
- Tested multiple sensors from the same batch — similar behavior.
- Tried 3.3V operation for ESP32 compatibility — readings are lower but still noisy.
- Placed the sensor at different depths in soil to see if that affects stability.
My Questions:
- What’s the best way to calibrate a capacitive soil moisture sensor (especially for analog output types)?
- Is it normal to see reading drift over time, or could this be due to temperature / soil conductivity changes?
- Would adding software averaging or filtering (like moving average) help with stability?
- Any coating or protection methods you recommend to prevent corrosion or moisture damage to the sensor PCB?
- Has anyone compared this sensor to digital options (e.g., I2C capacitive sensors) for better consistency?
Thanks in advance!
