I've had an IC-2730a installed in my truck for a little over two years now and it has performed like a champ. When talking on a local repeater, I've been told that my audio just drifts out at times. My transmission at 5W is still keying the repeater, but the audio just seems to fade away. I do not seem to have the issue at 10W or 50W. I've tried reseating all the connectors and have checked the coax. I still need to check the connection of the NMO antenna mount. I've checked my hand position on the mic to ensure I'm not accidentally covering it. My thoughts are that it is a geography issue since most of the reports are when I'm traveling through low-lying areas, but others do not seem to have that issue when traveling through the same area(s). I'm wondering if there is anything I'm not thinking of that could be causing that kind of audio loss. TIA!
